I have a nearly completed project and I need to modify the specifications for a specific class of fittings. After editing the catalogue and specs how can I update the out dated refferenced specs?
Thank you,
Henry
an easy out would to be add the new spec under a different name, and use the new parts. I have had to do this a couple times. It does not work if you need to modify the old fittings in the drawing though.
Thanks, John.
I guess I'll be modifying the existing parts as required. I was hoping to escape that.
Unfortunatly that has been my experience.. hopefully someone else can give us both good news 8(
