AutoCAD Plant 3D Forum
Updating Specs retro activly
3 REPLIES 3
AnandHarrypersad
386 Views, 3 Replies
I have a nearly completed project and I need to modify the specifications for a specific class of fittings. After editing the catalogue and specs how can I update the out dated refferenced specs?
Thank you,
Henry
3 REPLIES 3
an easy out would to be add the new spec under a different name, and use the new parts.  I have had to do this a couple times.  It does not work if you need to modify the old fittings in the drawing though.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
Thanks, John.
I guess I'll be modifying the existing parts as required. I was hoping to escape that.
Unfortunatly that has been my experience.. hopefully someone else can give us both good news 8(
Master Yoda.
”Boost
