Solved by KenFauver. Go to Solution.
Depending on what version of Plant 3D you're using you can tell Spec Editor to not update the descriptions when doing an Update Spec from Catalog.
Open Spec Editor and go to Spec > Update Specs From Catalog Settings. In this dialog you can pick and choose what data fields get updated.
