AutoCAD Plant 3D General DIscussion
Valued Contributor
19820415
Message 1 of 4 (379 Views)
unrecognized chinese character in exported Excel file when created ISO
379 Views, 3 Replies
02-15-2012 07:43 PM
As you know,when we create ISO,we can export relevant Infor to excel file just like BOM,cut piece and so on.
But if there is any chinese character in it,these chinese character will display as unrecognized in the excel file.
Version:smileytongue:lant3D 2012 64 bit
it seams that it happens in 2012 and the future version 2013.
Any solution?
thanks and regards
Employee
VickyADSK
Message 2 of 4 (360 Views)
Re: unrecognized chinese character in exported Excel file when created ISO
02-16-2012 10:48 PM in reply to: 19820415
Command: PLANTPCFUNICODE > ON
Then create iso. the loc language should be displayed correctly in table reports.
Vicky
Autodesk Plant Solutions
Valued Contributor
19820415
Message 3 of 4 (348 Views)
02-19-2012 09:31 PM in reply to: VickyADSK
Thank you Vicky.
But it still doesn't solve this problem.
when we set PLANTPCFUNICODE as ON,it do make some change with the output excel file.
but the chinese character is still display as unrecognized.
pls see attached pictures.
hope there is some better solution.
thanks in advance.
Rong
Employee
VickyADSK
Message 4 of 4 (300 Views)
03-05-2012 11:19 PM in reply to: 19820415
Thank you Rong.
We're looking into the limitation.
Vicky
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
