AutoCAD Plant 3D Forum
unrecognized chinese character in exported Excel file when created ISO
3 REPLIES 3
706 Views, 3 Replies
As you know,when we create ISO,we can export relevant Infor to excel file just like BOM,cut piece and so on.
But if there is any chinese character in it,these chinese character will display as unrecognized in the excel file.
Version:plant3D 2012 64 bit
it seams that it happens in 2012 and the future version 2013.
Any solution?
thanks and regards
Tags (1)
3 REPLIES 3
Vicky.Wu
Command: PLANTPCFUNICODE > ON
Then create iso. the loc language should be displayed correctly in table reports.
Vicky
Autodesk Plant Solutions
in reply to: Vicky.Wu
Thank you Vicky.
But it still doesn't solve this problem.
when we set PLANTPCFUNICODE as ON,it do make some change with the output excel file.
but the chinese character is still display as unrecognized.
pls see attached pictures.
hope there is some better solution.
thanks in advance.
Rong
Tags (1)
Vicky.Wu
Thank you Rong.
We're looking into the limitation.
Vicky
”Boost
