I have had to delete existing drawings in a project and redraw but when I input the valve tag numbers it states please use a unique valve numer as the number is alread allocated in the project. When I have a look in my data manager there is no record of these tags, I have noticed replies stating to edit the tag after it is placed but this results in a question mark appearing as the tag is a duplicate.
Please help me as this is frustrating and holding my work load back when I have tight deadlines to meet
thanks
Andy
Hi Andy,
Try running the Audit Project command from the Project Manager. This should remove any unreferenced data from your project database and release the tags that you are trying to use.
Andy
Thanks Andy
I have tried this so many times and purged the drawing also with no result it is completly baffleing me.
I believe others have had this problem and have had no sucess
I have 18 very busy P&IDs with this issue with a tight deadline and there is no time for redraw.
Cheers
Andy
How are you you 'deleting' your drawings ready to start again? Are you removing them from the project and adding them again or are you selecting the contents of the drawings and erasing everything?
One thing you could try as a last resort, is to create a new project using your current project as a template and then copy your existing drawings in to your new project? Just a thought.
Andy
The drawings are being copied from another project as the area is exactly the same so rather than redraw I am bringing in what I have created before but when I open the project manager every instrument turns to no target and all valves and equiptment turn to a standard symble with no properties. so I have deleted all valves and symbols and replacing them with new ones then it has the conflicting tag numbers.
hope this makes sense
cheers
Andy
If you are simply copying the drawings over the top of the originals using Windows Explorer then I suspect that you are confusing the project manager big time as none of the database references in the new file will be valid - hence the no target errors.
You need to remove the drawings that you want to update from the project, then use the Copy Drawing to Project command in Project Manager to copy the 'new' drawings. Alternatively, wblock out the contents of the 'new' drawings, erase the contents of the 'old' drawings and then insert and explode the wblock'ed drawings into the drawings you are updating.
Andy
Wondering if you found a way to get rid of the phantom tags. I've had issues with this if I have added a tag and then had a fatal error before I saved. Anything I added will leave some sort of phantom tag. I cannot find it and cannot Validate it out or Audit it out.
Audit here isn't the normal AutoCAD Audit. It's the "Audit Project" option that you see if you right click on the project name in the Project Manager. This should remove tags that are reserved but not used after a crash.
If autdit project doesnt work, you can try adding a "." as suffix for the "number". Or create a new property for the sequence number field and replace the existing with it, then change all the valve tags to refresh it. Hope it helps.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
