AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Unable to load spec file ***?
2 REPLIES 2
ome700
1529 Views, 2 Replies
Hello.
I am new user of AutoCAD Plant 3D 2013.
I have a problem. when ever I tried to select some spec from Home>Part insertion tab they returen error
"Unable to load spec file XXX"
X =Selected spec name..
Pic is attached for referance. Please note that not all of my Spec return error. Some spec load without any error.
I tried to restart the application and reloading project but the problem is not solved.
Please help me in this regard.
BR
umair
Tags (3)
2 REPLIES 2
KenFauver
in reply to: ome700
Make sure that you have the spec pathing correct. There may be a typo.
If the post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Kenneth G. Fauver
Technical Sales Specialist – Plant
Oil and Gas Solutions
matparodi
in reply to: ome700
Follow these steps:
  • In Project Manager right-click the node "Pipe Specs" and select from context menu "Copy Specs to Project..."
  • Search for the spec you want in the Spec Folder of the Project <XXX>.pspx and copy it to the project
  • Close the Plant 3D software and open again.
Sorry for the late answer, hope this could help you
MJ Parodi - BIM Coordinator
”Boost
