AutoCAD Plant 3D General DIscussion
Active Contributor
tarrynd
Message 1 of 7 (759 Views)
Unable to create own actuators in Catalog
759 Views, 6 Replies
06-07-2012 11:22 PM
Hi All
I am currently trying to set my actuators in my catalog. Now I don't want to use the default actuators provided (as seen in attached image "Acuator list"), I would like to rather use ones that I have created, but when i try create an actuator, using the create new components option under catalog editor, after specifying my information (as seen in image "Actuator I would like to add"), the actuator does not appear in my list of components in my catalog like the other actuators do. Can anyone please help?
Product Support
Dan.Scales
Message 2 of 7 (735 Views)
Re: Unable to create own actuators in Catalog
06-12-2012 09:01 AM in reply to: tarrynd
I can't reproduce this issue.
Could you provide detailed steps of the workflow that you are using?
Dan
Dan Scales
Active Contributor
Slepe
Message 3 of 7 (640 Views)
10-19-2012 01:16 AM in reply to: Dan.Scales
I have also samekind problem.
When I have filled all information of the actuator in Create New Componen-section and pushed Create-button, the actuator doesn't appear anywhere?
Program Autocad Plant 3D 2013
Active Contributor
tarrynd
Message 4 of 7 (473 Views)
02-11-2013 02:18 AM in reply to: tarrynd
Hi There
My workflow is exactly that of which I would use to create any other component. In the Spec Editor I open my catalog and select "Create New Component", I then select "Actuators" under component category, and choose "ValveActuator" under piping component, then give a short description, choose metric sizes and fill in Manual for operator type and Hand Wheel under Actuator type. I then select the Handwheel image and say Create and nothing happens.
Tarryn
Active Contributor
tarrynd
Message 5 of 7 (469 Views)
02-11-2013 02:54 AM in reply to: tarrynd
Hi All
I know what the problem is. If you change the Actuator from Imperial to Metric it doesnt work. Unfortunately I do not have a solution though.
Not sure if anyone else has figured this out?
Tarryn
Active Member
cyklosarin
Message 6 of 7 (427 Views)
03-07-2013 12:14 AM in reply to: tarrynd
Same problem here. Can someone give any solution on this?
Regards
Active Member
islanddrafting
Message 7 of 7 (411 Views)
03-07-2013 03:09 PM in reply to: tarrynd
yes also no chain wheel
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
