AutoCAD Plant 3D Forum
Unable to add P&ID symbols
4 REPLIES 4
1553 Views, 4 Replies
 “This tool is not supported in a non PNID drawing file.” message is displayed, when  P&ID tool plate symbol is clicked under windows “Regional and Language Options \ Standards and formats” setting is set to Turkish.
Windows XP SP3
Autocad Plant3d 2011 SP1
4 REPLIES 4
sankarg
The drawing on which you are trying to place the tool - is it part of the pnid drawings of the currently opened project? This message will be displayed when the drawing file is not part of the pnid drawings of the current project.  Are you able to create slines using sline command in that dwg file?
Sankar Ganesh
Sr. Principal Engineer
Autodesk Plant Solutions
Autodesk, Inc
     I am having the same problem. Even though I try to edit a PNID drawing belonging to a sample project, I get the same message ''this tool is not supported in a non pnid drawing''. And yes, I can create slines using sline command in that dwg file.
in reply to: sankarg
Today i installed AutoCAD P&ID 2012, everythings is normal. But when i click on an equipment on the tool palettes. This warning is occuring. Is there any one knows how to solve this problem ??
mgalicki
I can't even get to my PNID tool palettes or toolbars or menus?? Help please.
Maek
Everything in existence was first an Idea
Autodesk Plant 3D Premium 2019
Autodesk MEP 2019
HP 3.2 Ghz CPU 16 ram
1TB 7200 rpm SATA 6Gb/s hard drive
2GB DDR3 NVIDIA GeForce GTX 680ti
HP 2311x 23" LED Monitor
”Boost
