AutoCAD Plant 3D Forum
Un-wanted 25mm pipe cut
1 REPLY 1
vannmannen
333 Views, 1 Reply
When I press the + sign on a pipe to add afitting, the fittings gives me automatically a cut piece of 25mm on insertion.
The 25mm piece comes no matter if I place a flange, reducer or tee, and I really do not want ir need it.
Any way I can turn off this setting?
See attachment
1 REPLY 1
Peter_Jansoone
in reply to: vannmannen
The 25 mm is the minimum pipe length as set in the project setup.
But you can enforce a fittin to fitting connection. After you selected the symbol enter F on the command line or select Fitting-to-fitting from the right-mouse menu.
Peter Jansoone
Plant Design software consultant at Arkance Systems Belgium
”Boost
