AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Tree Structure required for Structural Member
1 REPLY 1
Arun_Kumar_K
399 Views, 1 Reply
Today, I find an issue in generating the cummulation of structural member required for aux. steel structure for pipe supports in Plant3d space.
I need to give for procurement only the auxiliary steel structures required for pipe supports.
When I saw the datamanager, the complete members which are in the project are displaying, which includes, pipe rack members, building beams, gratings etc.,  There is no division like support, stairs, pipe rack, building etc.,
As like Line numbers, for structures also, some class to be defined, the modelled structures should fall under the class.
1 REPLY 1
You could add a new property in against steel members in the project set up. A property that has a drop down list so you can define its classification.
Then you can use the report creator to output a procurement report.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Jarrod Mudford
Plant Solutions Consultant
Global Services
Autodesk, Inc.
”Boost
