I was originally trying to export and import a customized tool palette. But somewhere along the way, I completely lost my P&ID PIP tool palette. When I pick it, it loads everything. I had changed the path to point to where my exported palette is, but that didn't work (they wouldn't load in a new project - everything showed up on the palette just fine, but when I picked something to insert, it said it wasn't in that directory). Also when I was exporting, it kept making duplicates at the bottom on the Tool Palette list so I deleted those. So, I probably deleted something important. I kept trying import the one on top because it was in bold and had my new tab in there, but it just wouldn't work. So anyway, I entered the original path back in and as I said earlier, it just comes up with "all palettes". Plus the lines, etc. do not look like they used to on the P&ID PIP palette. Please help.
Thank you.
