AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
tool palette issue
9 REPLIES 9
Message 1 of 10
mdelaney
1033 Views, 9 Replies
tool palette issue
When I try to load my tool palette from the Spec Viewer, it gives this error message I have attached to the post. Please advise?
9 REPLIES 9
Message 2 of 10
pendean
in reply to: mdelaney
1. Is the problem with ALL toolpalettes or just this one?
2. Is the problem all the tools in this palette or just this one?
3. Is the problem in ALL your files, or just this one?
Dig a little deeper, provide more detailed information with more observed actions.
Message 3 of 10
dave.wolfe
Does the behavior repeat if you have PLANTDYNAMICTOOLPALLETE enabled? You may just want to turn that on to generate the palette for you, and then turn it back off.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 4 of 10
mdelaney
I tried the suggestion given and received this error message that I have attached.
Message 5 of 10
Arun_Kumar_K
We are also facing the same problem. Fatal error comes when we select the create tool pallete.
Message 6 of 10
dave.wolfe
in reply to: Arun_Kumar_K
Is SP 1 installed or Extension 2?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22757762&linkID=14116968
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 7 of 10
Arun_Kumar_K
Installed SP1 today, not facing this issue now.
Message 8 of 10
Arun_Kumar_K
Thanks Dave.
Message 9 of 10
mdelaney
Thanks Dave works perfectly.
Message 10 of 10
dave.wolfe
Great!
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
”Boost
