AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
To Run Navisworks Within Autocad Plant 3D
1 REPLY 1
kumarswapan64
734 Views, 1 Reply
I want to run the Navisworks within Autocad Plant3D but the option I couldn't fount into the Plant3D. Please see two attached files.
In command line typed "NWNAVIGATOR". then autocadplant3D hanged or exit.
please help me....
Swapan Kumar
1 REPLY 1
dgorsman
in reply to: kumarswapan64
Try doing a re-install on Navisworks (shouldn't need to uninstall, re-installation can be done from the Control Panel), keep an eye for installation options specifically the Navigator.  If Navisworks was installed before Plant3D it wouldn't have the opportunity to add the Navigator plug-in.
”Boost
