AutoCAD Plant 3D Forum
Title block fields and attributes
4 REPLIES 4
Gablafrance
1871 Views, 4 Replies
Hi everyone,
I've been asked to create a new .dwt for P3D ortho drawing and I have to add fields in the title block that are linked to project information such as Client name, project name, author, project manager. I'd like to know if it's possible to link those fields to the project set-up so I only have to enter those once and modify them after if the author of the drawing change or whatever.
I know my english isn't perfect so feel free to ask question, I really need an answer
Gab!
4 REPLIES 4
milic.srdjan
in reply to: Gablafrance
Why....
Too Complicate....
It is good idea I think to make template for ORTHO drawings with information that You need to be fix....and put additional information as block with attributes....
Always , when You start dialog for ORTHO creation You have chance to start with template...
and..at end I think that is possible do make ....
I do not have time to post all work flow but if You look at....
http://docs.autodesk.com/PLNT3D/2013/ENU/filesPCR/GUID-745794C2-1657-4393-92F0-B20A03B38F62.htm
You will find additional information....
Srdjan
Gablafrance
in reply to: milic.srdjan
My template is already created and works well, all the fields have been added. My problem is to link those fields to project properties so they fill themselves when I set-up a new project, because, for the moment, I have to fill them by the drawing properties menu.
this is possible, when you insert a field, there is a new entry called "Project" and that has the P3D project properties to add in as fields.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
I finally found out how to do, thanks a lot for your replies!
”Boost
