I am finding that ANYTIME, that any changes are made in the Project Setup , Isometric DWG Settings , Title Block and Display, Setup Title Block
that both the border and title block disapear and do not print the next time that I run and ISO. I have had to re-insert the border/title block 4 already this morning.
I am also having trouble changing the North Arrow from its default position, I am setting up two different projects, the first one i was able to change the north arrow position to (up- right)....although I had to reinsert the border and title block
The second project i am unable to change the north arrow position, in fact when i open the "setup title block" I can see that it is in the changed position, for about 1 second as I open it, but then changes to the default position, and of course i am forced to re-insert the titile block / border each time I make an attempt
Not Good........Not good at all
Change the block name of your iso titleblock to Title Block after you insert it. This will probably fix the north arrow issue as well
