AutoCAD Plant 3D General DIscussion
thebearjed
Message 1 of 5 (1,147 Views)
This annoying...line number
1147 Views, 4 Replies
03-28-2012 06:31 AM
i have a set of P&ID's that already have all the line numbers assigned. the client wants a different style of line number format. no problem, i edit the pipeline tag to generate the desired fields and start changing the line numbers on the P&ID's.
for whatever reason about 1 in 10 line numbers keep reverting back to the old line number. i keep re-assigning the new line number and it still reverts back?????
When you assign the tag again, does the "Tag Format:" listed up near the top of the Assign Tag window match up to the new one in project setup?
Product Support
jason.drew
Message 2 of 5 (1,126 Views)
Re: This annoying...line number
03-29-2012 02:23 PM in reply to: thebearjed
Jason Drew
Premium Support Specialist
Product Support
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
Roxana-Elena
Message 3 of 5 (1,114 Views)
03-30-2012 02:38 AM in reply to: thebearjed
in the Project Setup/Lines/Pipe Line Segments (or Pipeline Group) and Properties: TagFormat/Dafault Value: "X" same as the one createed by you. Same for Annotation: you coose same block as the one desired to be shown on your drawing (next to Tag format)
I believe Jason.Drew recomended same
Roxana
thebearjed
Message 4 of 5 (1,107 Views)
03-30-2012 06:10 AM in reply to: Roxana-Elena
no, it does not match the one in project setup?
Roxana-Elena
Message 5 of 5 (1,101 Views)
03-30-2012 06:42 AM in reply to: thebearjed
just match them and this should solve your problem.
Roxana
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
