AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
The nozzle catalog could not be found at \NOZZLE Catalog.acat
6 REPLIES 6
lewisparkins
2523 Views, 6 Replies
Im trying to create a new piece of equipment. Clicking on the button (_PLANTEQUIPMENTCREATE) I get the message in the comand line
"The nozzle catalog could not be found at \NOZZLE Catalog.acat"
I have the "Nozzle Catalog.acat" in "C:\AutoCAD Plant 3D 2015 Content\CPak Common" and in "C:\AutoCAD Plant 3D 2015 Content\Migrated Content 4_0"
whats wrong? how do i get AutoCAD to find them there?
6 REPLIES 6
patpat79
in reply to: lewisparkins
How many users are doing your project?
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
lewisparkins
in reply to: patpat79
Just me
patpat79
Try using the command "PLANTMODIFYSHAREDCONTENTFOLDER" so you could check if your content folder's location is correct or your nozzle catalog's location is "really" correct.
Best Regards,
Pat Andres
GHD Manila
lewisparkins
The specified location was correct, but the file "ContentConfig.xml" wasnt there. I copied it over from my 2013 release and all is working now.
Thanks patpat79
robEJUBA
Hi
I'm experiencing the same problem, the ContentConfig.xml is missing.  I'm using Autocad Plant 3D 2019 and can't locate the file anywhere.  Where can I get it?
Thanks in advance
Tried a Repair/Reinstall?
”Boost
