AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Text form 3D model to orhto
6 REPLIES 6
TarmoSaar
735 Views, 6 Replies
Hi
does anyone know how to get text form Plant 3D model space to Ortho viewport?
If i make a ortho view, i can see only lines and circles.
At the moment i make block symbol from texts and then place this on Viewport.
I have a building model made in AutoCAD Archidecture and it has lot of information attached to it. For example axes numbers that i need to show on ortho view.
Tarmo
6 REPLIES 6
rkreiss375
in reply to: TarmoSaar
I am having the same problem.
Tarmo, did you resolve this problem?  If so, how?
Can anyone else help?
Rod
JohnHolder
I had a similar issue ages ago... but I forgot what I did to fix it. Have you checked the text style and layer? or exploding them?
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
TarmoSaar
in reply to: rkreiss375
I haven´t found any reasonable solution for that problem.
Im open for suggestions.
Tarmo
KenFauver
If you right-click on the viewport their is a command on the popup called "Convert MS to PS". This will pull entities from modelspace into paperspace.
If the post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Kenneth G. Fauver
Technical Sales Specialist – Plant
Oil and Gas Solutions
stian_storesund
Hi
If you use the command: TXTEXP, you explode the text, then it will show in the ortho-view
Regards
Stian
Stian,
That was the command I was looking for.  That works, thanks for the reply.
Rod
”Boost
