AutoCAD Plant 3D General DIscussion
3 Kudos
Post 1 of 7
Text form 3D model to orhto
348 Views, 6 Replies
06-06-2013 02:00 AM
Hi
does anyone know how to get text form Plant 3D model space to Ortho viewport?
If i make a ortho view, i can see only lines and circles.
At the moment i make block symbol from texts and then place this on Viewport.
I have a building model made in AutoCAD Archidecture and it has lot of information attached to it. For example axes numbers that i need to show on ortho view.
Tarmo
Hi
If you use the command: TXTEXP, you explode the text, then it will show in the ortho-view
Regards
Stian
0 Kudos
Post 2 of 7
Re: Text form 3D model to orhto
01-03-2014 11:10 AM in reply to: TarmoSaar
I am having the same problem.
Tarmo, did you resolve this problem?  If so, how?
Can anyone else help?
Rod
Valued Mentor
18 Kudos
Post 3 of 7
01-03-2014 12:16 PM in reply to: TarmoSaar
I had a similar issue ages ago... but I forgot what I did to fix it. Have you checked the text style and layer? or exploding them?
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
3 Kudos
Post 4 of 7
01-09-2014 12:34 AM in reply to: RodKreiss4326
I haven´t found any reasonable solution for that problem.
Im open for suggestions.
Tarmo
Employee
13 Kudos
Post 5 of 7
01-09-2014 02:52 PM in reply to: TarmoSaar
If you right-click on the viewport their is a command on the popup called "Convert MS to PS". This will pull entities from modelspace into paperspace.
If the post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Kenneth G. Fauver
Technical Sales Specialist – Plant
Oil and Gas Solutions
New Member
0 Kudos
Post 6 of 7
01-10-2014 06:06 AM in reply to: TarmoSaar
Hi
Regards
Stian
0 Kudos
Post 7 of 7
01-10-2014 07:03 AM in reply to: stian.storesund
Stian,
That was the command I was looking for.  That works, thanks for the reply.
Rod
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
