AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Tap Port (hole in blind flange)
6 REPLIES 6
jeremylegleu
2185 Views, 6 Replies
Does anyone know how to do a "tap port" on a blind flange?  What that means is drilling a hole in a blind flange and threading it to bleed a line.  I know in bentley it was possible, I am not sure if it is possible in CAD Plant 3D, an help/advice is appreciated!!
6 REPLIES 6
It's possible in Plant3D 2013.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk ANZ YouTube Channel
Ok, we are using 2012 here.  Thank you for your response!
mtchad
in reply to: jeremylegleu
How do you do this in Plant2013?
Arun_Kumar_K
in reply to: mtchad
Set some size below than the main size, then tap the line from blind flange
in reply to: TomislavGolubovic
Reviving and older problem but I am having some issues with changing the tap connection to a threaded tap instead of welded. Any way to do this?
Currently my nipple just sits on top of the blind as seen in the attached image. It throws out the dimensions. I thought maybe the catalog would have a hub flange but it doesn't. How would you go about this?
Disregard previous post.
Sorry...wish there was a delete post function.
”Boost
