AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Tags (or Labels or Balloons) in 3D Piping Environment
10 REPLIES 10
Message 1 of 11
volkan
1162 Views, 10 Replies
Probably this is a very easy thing to do but I can't find a solution.
I want to give permanent tags (or labels or ballons) in 3D piping environment to pipelines so I can easily identify their line number when I look at them. You may think the "label" as the image below but the label should remain permanent on the selected pipelines for easy identification.
Hope I can describe my question well.
Volkan
Volkan ARI
10 REPLIES 10
Message 2 of 11
jabowabo
in reply to: volkan
I'm pretty sure this is not possible out-of-the-box.  The only tagging that can be set up in the project manager is for orthos.  However, this can be done with LISP or .Net if you have someone on staff familiar with either.
Message 3 of 11
volkan
in reply to: jabowabo
Thank you very much for your answer. I don't have any experience with .net and lisps. So i think it's better to manage those pipelines via layer manager. 🙂
Volkan ARI
Message 4 of 11
jabowabo
in reply to: volkan
Here's a quick example of how to accomplish this with LISP:  P3dTagLine
Message 5 of 11
volkan
Thank you very much. I load the lisp via appload and it works like a charm. You save my day. 🙂
Volkan ARI
Message 6 of 11
enriquemiyaGUA6S
Hi Guys, how to download the lisp file?
Message 7 of 11
willinsuite
Do you still have this lisp file, the Box says its no longer there.
Message 8 of 11
jabowabo
in reply to: willinsuite
; wjasonhudson@gmail.com
; Note: Current mleader style needs to be type Multileader Type: "Mtext"
(defun c:TagLine ( / myEnt vlaobj lineNumTag mlObj)
  (vl-load-com)
  ; get the line number from piping obj
  (setq myEnt (car (entsel)))
  (setq vlaobj (vlax-ename->vla-object myEnt))
  (setq lineNumTag (vlax-get-property vlaobj 'LineNumberTag))
  ; create the mleader.
  (command "_MLEADER" pause pause "")
  ; change mleader text to line number tag
  (setq mlObj (vlax-ename->vla-object (entlast)))
  (if (= (vlax-get-property mlObj 'ObjectName) "AcDbMLeader")
    (vlax-put-property mlObj 'TextString lineNumTag)
    (exit)
  (princ)
Message 9 of 11
willinsuite
Oh I see, This doesn't work when the Piping is Xref'ed in.
Message 10 of 11
jabowabo
LISP cannot access that info in an Xref - you can do it through .NET but it's tricky.
Message 11 of 11
willinsuite
Yeah it's a real pain. I co-wrote a lisp a year or so ago that was able to do it but it has magically been deleted from the cloud drive it was stored on.
”Boost
