AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
TAG Orifice Plates
4 REPLIES 4
Gabriel.N
2158 Views, 4 Replies
TAG Orifice Plates
How to TAG Orifice Plates?
Check annex image.
Tags (2)
4 REPLIES 4
Attila.Vallyon
in reply to: Gabriel.N
Instead of creating custom part orifice plate, set up a proper part in a catalogue and insert in a pipe spec. Than you have a tagged orifice plate.
Or you have to check the project settings:
Plant 3D class definitions \ piping and equipment \ pipe run component \ orifice plate
Check if is there a tag format. If there is not, than you have to create one.
Attila Vallyon
Gabriel.N
in reply to: Attila.Vallyon
I will try,
Tank you.
Gabriel.N
I added the orifice plates to the pipespec, but that did not solve the problem.
The solution was actually add a TAG Format to the Plant 3D Class Definition, in my case I added on "root" pipe run component for all.
Thank you very much.
 how can i create an orifice ?
thank you
”Boost
