AutoCAD Plant 3D General DIscussion
Active Member
0 Kudos
Post 1 of 4
Tag errors
304 Views, 3 Replies
05-31-2011 03:50 PM
Good day
I have this error showing up everytime i want to change a tag "39-BX-016?" It says:
"Another asset in the project has the same tag which has not been saved. Cannot merge with that tag. Please enter a unique tag."
I'm pretty sure that there is no such duplicated tag. Thanks in advance.
Valued Mentor
65 Kudos
Post 2 of 4
Re: Tag errors
05-31-2011 07:49 PM in reply to: ITM3mexicana
use the data manager...find the TAG column (you may need to add it through the Plant 3D Class Definitions section of the project setup)
click on the tag column heading to sort then scroll till you find the tag number (make sure you have the whole project selected in the data manager)...then if you click on the first column of the the item then plant will open the dwg containing the item and zoom to it so you can either retag or delete it.
Hope this works for you
Cheers
RichO
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Valued Contributor
12 Kudos
Post 3 of 4
Re: Tag errors
06-02-2011 10:34 AM in reply to: ITM3mexicana
Delete the element and reacreate the same element.
Member
0 Kudos
Post 4 of 4
Re: Tag errors
08-21-2012 05:49 AM in reply to: bogdanov.y
this does works, no one solutions that is given by the experts can solve this issue...
Post to the Community
New Post
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
