I placed tag nos on my specialty items on my 3d piping model.
Is there a way that will enable them to have a Iso tag call out like for the valves, instrument and support.
Solved by dave.evans. Go to Solution.
Here is some sample for a PulledPipe Iso extraction, you can see the method and modify it.
There is a custom database field, sCutLength that is used via triggers to round the cut length to one decimal place (you do not require this for your examle).
In IsoConfig.xml (note, back up this file before ANY manual edit)
In the
<!-- Static annotations --> section, make a new scheme, here you can see I have made two.
<!-- 'Dave Evans -->
<ComponentScheme Name="ElbowCoord" AnnotationStyle="Standard" Format="{0}" LeaderStyle="AlwaysCorner" Filter="ElbowCoord" Fields="CO-ORDS" />
<ComponentScheme Name="PulledBend" AnnotationStyle="Standard" Format="PULLED PIPE\nCUT LEN : {0}" LeaderStyle="AlwaysCorner" Filter="PulledBend" Fields="sCutLength" />
Now you need to make a filter, in the Filters section, right at the end of the file.
<!-- Dave Evans -->
<Filter Name="ElbowCoord" Value="Type = 'ELBOW' OR Type = 'BEND' OR Type = 'TEE'" />
<Filter Name="PulledBend" Value="SKEY='PBBW'" />
I hope this helps.
Regards
Dave
Technical Specialist - Plant
Northern Europe
Thanks Dave
I got an idea on how I will do my own component scheme and do the coressponding filter 🙂
Great!
