I want to create an syphon (u-form) as an olet.
The problem for the Isometric system is the change of the outside direction.
Is there a solution for Isometric possible
Steffen
Solved by Dan.Scales. Go to Solution.
Hi Steffen,
Could you post pictures showing the result that you get and the result that you want?
Dan
Hi Dan
i have attached the wrong, the right an the definition of the Isometric symbol.
I hope you can help me
Hi Steffen,
Try using the following Content Iso Symbol Definition:
SKEY=SYBW,TYPE=BEND
Setup your isometric symbol like this:
This is the resulting iso that I got:
Please let me know if this works for you.
Dan
Hi Dan.
it dosn't work.
When I see your isometric it seems to me, that your part is defined as bend . Our part is defined as olet which welded directly to the pipe.
Steffen
