AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Syphon as olet
4 REPLIES 4
1645 Views, 4 Replies
Syphon as olet
I want to create an syphon (u-form) as an olet.
The problem for the Isometric system is the change of the outside direction.
Is there a solution for Isometric possible
Steffen
4 REPLIES 4
Dan.Scales
Hi Steffen,
Could you post pictures showing the result that you get and the result that you want?
Dan
Dan Scales
in reply to: Dan.Scales
Hi Dan
i have attached the wrong, the right an the definition of the Isometric symbol.
I hope you can help me
Dan.Scales
Hi Steffen,
Try using the following Content Iso Symbol Definition:
SKEY=SYBW,TYPE=BEND
Setup your isometric symbol like this:
This is the resulting iso that I got:
Please let me know if this works for you.
Dan
Dan Scales
Hi Dan.
it dosn't work.
When I see your isometric it seems to me, that your part is defined as bend . Our part is defined as olet which welded directly to the pipe.
Steffen
”Boost
