hi Everyone,
i have created some supports (pipe clamps) in python for Plant 3d because the standard ones are nice but not like this what i want 😉
OSPC001 - Pipe clamp with threaded rod
OSPC002 - Pipe clamp with anchor (with 2 stretch points)
OSPC003 - Pipe clamp with threaded rod + base plate
OSPC004 - Pipe clamp with threaded rod ant nuts for fixing on steel construction (with 2 stretch points)
Everyone can use it. maybe other people have also some stuff and will share it. that would be nice 🙂
Nice coding! Looks great
Very nice Calmp support
So how can to add in plant 3D Catalog??
Ahmed Helal
hi,
Script Locations
Plant 3D will load custom scripts from a specific location. By default that location is C:\AutoCAD Plant 3D 2013 Content\CPak Common\CustomScripts\. If you do not have this folder, you can create it in the CPak Common folder.
Load Scripts into Plant 3D
Open Plant 3d and use the command "Plantregistercustomscript". after this it will be available in the catalog 🙂
regards Hermann
Well Done.. Thank for sharing, I am able to create something that I really really needed. Cheers, Peggy Lin
Thank you very much for sharing this!
I have been looking for some good examples of pipe supports to get an understanding of how they are made.
/Kaj
Thank you so much Sir, This python script helps a lot, your a legend. I have one question though, do you think It is possible to establish a SQL DB connection on this python custom script?
thanks again and God bless. 🙂
not sure what you mean.
if you mean if you get Bill of material out, then the answer is yes because it is part of the plant 3d enviroment.
if you mean if you can write something in the python code to etablish a SQL connection to anther not plant 3d script, then the answer is: i think it is not possible 😞
