AutoCAD Plant 3D Forum
Supports (Pipe clamps) in Python
10 REPLIES 10
Message 1 of 11
Hermann.Semlitsch
3910 Views, 10 Replies
hi Everyone,
i have created some supports (pipe clamps) in python for Plant 3d because the standard ones are nice but not like this what i want 😉
OSPC001 - Pipe clamp with threaded rod
OSPC002 - Pipe clamp with anchor (with 2 stretch points)
OSPC003 - Pipe clamp with threaded rod + base plate
OSPC004 - Pipe clamp with threaded rod ant nuts for fixing on steel construction (with 2 stretch points)
Everyone can use it. maybe other people have also some stuff and will share it. that would be nice 🙂
10 REPLIES 10
Message 2 of 11
Nice coding!  Looks great
** If my reply resolves this issue, please choose Accept Solution **
Scott Hallmark, Design Specialist | Fluor Corporation
Inventor and AutoCAD Certified Professional, Autodesk Certified Instructor | My Plant3D Notes | AU Speaker | ROLL TIDE!
Message 3 of 11
Very nice Calmp support
So how can to add in plant 3D Catalog??
Ahmed Helal
Message 4 of 11
hi,
Script Locations
Plant 3D will load custom scripts from a specific location.  By default that location is C:\AutoCAD Plant 3D 2013 Content\CPak Common\CustomScripts\.  If you do not have this folder, you can create it in the CPak Common folder.
Load Scripts into Plant 3D
Open Plant 3d and use the command "Plantregistercustomscript". after this it will be available in the catalog 🙂
regards Hermann
Message 5 of 11
Thanks for sharing!
Message 6 of 11
Thanks Very much,
Ahmed Helal
Message 7 of 11
Arun_Kumar_K
in reply to: Ahmed1081975
Thanks for your contribution and sharing of what you have done. Gr8 work done.
Message 8 of 11
Well Done.. Thank for sharing, I am able to create something that I really really needed. Cheers, Peggy Lin
Message 9 of 11
Thank you very much for sharing this!
I have been looking for some good examples of pipe supports to get an understanding of how they are made.
/Kaj
Message 10 of 11
Thank you so much Sir, This python script helps a lot, your a legend. I have one question though, do you think It is possible to establish a SQL DB connection on this python custom script?
thanks again and God bless. 🙂
Message 11 of 11
not sure what you mean.
if you mean if you get Bill of material out, then the answer is yes because it is part of the plant 3d enviroment.
if you mean if you can write something in the python code to etablish a SQL connection to anther not plant 3d script, then the answer is: i think it is not possible 😞
”Boost
