Hi
I have created new support Tag format like VBA-150-01 (i’e <valve type>-<size>-<number>). And for ortho annotation I have created like VBA-150 only. On my isometric drawing I want see the pipe support annotation like ortho annotation i’e VBA-150 ( <valve type>-<size>).
In isoconfig.xml file default coding is :-
<ComponentScheme Name="SupportTag" AnnotationStyle="standard" Enabled="true" Grouping="true" Tag="XX" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Filter="Support" Fields="TAG" />
Can anyone help me?
Can you send me the isoconfig.xml file and also the main model drawing. I will try to test it out and provide you a quick feedback.
please open the attached link
thank you for reply.
but the point is not solved.
the valve tagging is "VBA-150-001", || the valve annotation is "VBA-150" || and I want Iso annotation "VBA-150".
Support tagging is "SAS-150-001", || the support annotation is "SAS-150" || and I want ISO annotation "SAS-150".
I have modified Isoconfig.xml file coding :
for Valve
<ComponentScheme Name="TAG" AnnotationStyle="standard" Enabled="true" Grouping="true" Tag="XX" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Filter="NotBoltWeldFlangeGasket" Fields="TAG" />
for Support
<ComponentScheme Name="SupportTag" AnnotationStyle="standard" Enabled="true" Grouping="true" Tag="XX" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Filter="NotBoltWeldFlangeGasket" Fields="TAG" />
but not solved.
Vicky, you are absolutely correct, whatever valve/support tag I assigned in P3D that is display correctly in isometric drawing. As per our project requirement I want to display the valve/support tag in isometric drawing is <Type> and <Size> only, although the tag format in P3D is <Type>-<Size>-<Number>.
Present Setting is :
Tag Format : VBA-350-001 ( <Type>-<Size>-<Number>)
Orth Anno : VBA-350 (<Type>-<Size>)
Iso Anno : VBA-350-001 (<Type>-<Size>-<Number>) (Default setting is Isoconfig.xml file)
Our Project Requirement is :
Iso Anno : VBA-350 (<Type>-<Size>)
