AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Subtypes for valves in 3D
1 REPLY 1
334 Views, 1 Reply
In our company we have 10 different valve types (check valve, ball valve, safety valve…). Each valve type has in average 25 sub types with same pressure and facing.  If I place a valve in Plant 3D I have to choice the valve in a list of 250 entries. When i like to replace it I get also a list about 250 different valves in the context menu. Is there a possibility to create subtypes for valves in Plant 3D? For example: If I like to replace a check valve I would only see valves of type check valve?
1 REPLY 1
TomislavGolubovic
From the sounds of it, you are using the default spec that comes with Plant3D?
You can make your own spec for the particular project with only items that belong in the spec for that project/client.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
”Boost
