AutoCAD Plant 3D Forum
Substitue part pulldown
4 REPLIES 4
Dadspackard
572 Views, 4 Replies
Hi All,
As you can see we have list of Control and handvalves that show up in the pull down.
How can I edit the Substitute part pulldown to be a little more descriptive?
I did a search but could not find an answer.
Packin31
Tom
aka, Dadspackard, Packin31
4 REPLIES 4
joel_harris
in reply to: Dadspackard
Tom,
The values shown after selecting the Substitute Parts grip are the Long Description (Size) values from the spec.  Be sure you are populating those as well as the Long Description (Family) values in your specs.
Joel Harris
Designated Support Specialist
Autodesk, Inc.
Dadspackard
in reply to: joel_harris
Joel,
Thank you very much. That was it.
Tom  (Packin31)
Tom
GokhanKeskin
Joel hi,
Can we make changes so it will pick up Long Description"Family" instead of "size".
joel_harris
in reply to: GokhanKeskin
Currently, there is no way to change what appears in the substitution grip drop down.  However, you can post a suggestion to the IdeaStation for Plant located here: https://forums.autodesk.com/t5/autocad-plant-3d-p-id-ideas/idb-p/48/tab/most-recent.  The Plant developers review the IdeaStation frequently, and will try to incorporated those items with a high number of votes. Good luck! 🙂
Joel Harris
Autodesk, Inc.
”Boost
