AutoCAD Plant 3D Forum
Student Version Problems w/AutoCAD Plant 3D 2013
17 REPLIES 17
Message 1 of 18
marbtrjmr
2365 Views, 17 Replies
There is a problem with the Student Version of Plant 3D 2013.  The program will throw an exception error with the following message.
When creating a new P&ID file.
Unhandled exception has occurred in a component in your application.  If you click Continue, the application will ignore this error and attempt to continue.
Filer error
When entering Project Setup
Error Decrypting Data
I saw an question in Ask The Expert for Lori Wu on 6/19/2012 that this problem has been identified and Autodesk is working on it; however, I have seen messages for this problem since 3/2012.
How can we find out the status of this problem and if a fix has been identified?
Thanks.
17 REPLIES 17
Message 2 of 18
jmanlives
in reply to: marbtrjmr
Bump. It's still an issue.
Message 3 of 18
copeck21
I am having this problem not only on my home computer, but on 2 computers at school as well.  I have looked everywhere for a solution to this problem with no success, and have even called Autodesk only to get denied of help because I am a student and not a registered user.  This program is completely unusable since you cant create a new drawing from any component in project manager.  Autodesk, please find a solution to this problem.
Message 4 of 18
Does this happen on new Projects, or just the Sample one already installed?
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
Message 5 of 18
Hi!
I get the same problem every time when I am opening the program.
Attached the error.
I scanned whole computer, I installed on another one, tried version 32 also on a 64 still same error. Should I try a cracked version 🙂  to end all possibilities ? ( please read it as a joke :)) ).
Now seriously is any fix for this ?
Message 6 of 18
It happens on any project. You cannot create any type of new drawing without getting the error. I'm using the trial version right now and it works perfectly.
Message 7 of 18
enemykillerro
OMG! this is a noob problem imho how can you release a program if is not working from the start......nooobs! really sad....for a company like Autodesk.
Message 8 of 18
BTW if i try to install the trial version the educational enter automatucaly .I unnistalled the educational one before.Any suggestion ?
Message 9 of 18
 is so so so hard ? 🙂
Message 10 of 18
I am an instructor in Texas and all of my students are experiencing the same issue.  We are more than halfway through a semester, and the curriculum is tough without the ability to be able to work from home.  I experienced, personally with the student version, an exception after I opened my project and went to start a new drawing.  Any drawing, P&ID or Plant 3D.  So it isn't just the default project that is the issue.  Our projects work fine on campus, but not at home.  Please advise if there is a possible hot fix or any kind of solution.
Donna
Message 11 of 18
Rave.Tam
Check the solution for other similar post. It had already been answered before. This is caused by popup message that appears everytime you open a clean dwg. You will need to open and save all the template and pss manually using the student version. I have also blog about this some time ago.
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
Message 12 of 18
marbtrjmr
in reply to: Rave.Tam
Where is your blog?
Message 13 of 18
Rave.Tam
Its on my post signature..
Here's the direct link
http://lazcad.com/2013/03/how-to-make-plant-3d-student-version-works
Message 14 of 18
jhammonds
Thank you for your assistance with this problem.  As a student, however, I am not yet familiar with all of the ins and outs of this program and am unsure how to implement the fix you suggested in your blog.
Could you please supply some step-by-step instructions for implementing this fix.
Thank you.
Message 15 of 18
Rave.Tam
in reply to: jhammonds
First, search for ProjectSymbolStyle.dwg in the Project Directory. Open that drawing and save it.
After that, go to Project Setup. In P&ID, Plant 3D and Isometric DWG Settings, under Path and it should show you all the DWT files in the Project. Open all these DWT files and save it.
Generally, all templates is located here.
%localappdata%\Autodesk\AutoCAD Plant 3D 2013 - English\R19.0\enu\Template
If you don't understand any of the terms, you can look it up in the help files.
Message 16 of 18
andrewgcross
Thanks for that! If anyone has problems locating ProjetSymbolStyle.dwg, mine was actually titled projSymbolStyle.dwg. It was definitely in the root of the project folder.
Message 17 of 18
hung.tam
in reply to: andrewgcross
Thanks for correcting the file name, didn't notice it until i now.
Message 18 of 18
jan_senden
now works nothing.
I want to create a new drawing.
Auto cad plant 3d ignores... nothing happens.
i have to try to save the templates sheets.. but it dont works...
is it possible to send a video tutorial ??
I started to cry !!!
please help
”Boost
