AutoCAD Plant 3D General DIscussion
Active Contributor
hendriksegveld
Message 1 of 4 (672 Views)
stud bolt length 2013
672 Views, 3 Replies
02-25-2013 03:06 AM
See attachment. I'm creating in the ASME catalog stud bolts with custom lengths 80mm-100mm-120mm-140mm and so on.
For example: 4"-150# studbolt length is 120 mm. In the catalog I fill in: 120 mm. When I create an isometric, in the BOM I see on the @@@ marks the length 120.65 mm and in the size coloumn 5/8" x 121 mm. Length should be 120 mm.
I had this problem before in 2011 version, was solved in 2012 version and back now in 2013 version??? Please advise.
Do I have to add some information in the "bolt length mapping" module and how (that's new in 2013)?
With kind regards, Hendrik Segveld
Active Contributor
hendriksegveld
Message 2 of 4 (541 Views)
Re: stud bolt length 2013
03-13-2013 04:26 AM in reply to: hendriksegveld
Question from 25 feb 2013 and still no solution. I tried severall allready cases. Does anyone have the same problem? or better, does someone have the solution?  Could be the problem in the P3D2013 "Bolt Length Mapping Dialog Box"?
serafin.albiero
Message 3 of 4 (536 Views)
03-13-2013 05:47 AM in reply to: hendriksegveld
The bolt length calculation was explained here !
Just take a look.
Serafin A. Albiero Jr.
Active Contributor
hendriksegveld
Message 4 of 4 (493 Views)
03-15-2013 05:47 AM in reply to: serafin.albiero
I checked the above mentioned explanation, but somehow it doesn't work for me. What do I wrong? See the attachment with the steps I followed. (document Studbolt length 2). Should I add the new custom length 80-100-120-140 mm, and so on, to the "Bolt length mapping"? With Kind Regards, Henk Segveld
Post to the Community
New Post
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
