AutoCAD Plant 3D Forum
stud bolt length 2013
3 REPLIES 3
1417 Views, 3 Replies
See attachment. I'm creating in the ASME catalog stud bolts with custom lengths 80mm-100mm-120mm-140mm and so on.
For example: 4"-150# studbolt length is 120 mm. In the catalog I fill in: 120 mm. When I create an isometric, in the BOM I see on the @@@ marks the length 120.65 mm and in the size coloumn 5/8" x 121 mm. Length should be 120 mm.
I had this problem before in 2011 version, was solved in 2012 version and back now in 2013 version??? Please advise.
Do I have to add some information in the "bolt length mapping" module and how (that's new in 2013)?
With kind regards, Hendrik Segveld
3 REPLIES 3
Question from 25 feb 2013 and still no solution. I tried severall allready cases. Does anyone have the same problem? or better, does someone have the solution?  Could be the problem in the P3D2013 "Bolt Length Mapping Dialog Box"?
serafin.albiero
The bolt length calculation was explained here !
Just take a look.
Serafin A. Albiero Jr.
in reply to: serafin.albiero
I checked the above mentioned explanation, but somehow it doesn't work for me. What do I wrong? See the attachment with the steps I followed. (document Studbolt length 2). Should I add the new custom length 80-100-120-140 mm, and so on, to the "Bolt length mapping"? With Kind Regards, Henk Segveld
”Boost
