AutoCAD Plant 3D General DIscussion
Valued Mentor
ybogdanov
Message 1 of 4 (402 Views)
Stub-in orientation in ISO
402 Views, 3 Replies
04-16-2012 01:56 PM
 another comment. The program insert with incorrect orientation all stub-in connecions. It's happen when the stub-in it's not form part of the iso:
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Valued Contributor
batone79
Message 2 of 4 (293 Views)
Re: Stub-in orientation in ISO
01-10-2013 05:01 AM in reply to: ybogdanov
Did you resolve it?!....
I have one day and a Half trying to find a answer at the moment, my solution is when generate ISO.dwg, rotate each one acad block "SplitMark" to right direction, from properties.
If you have a better solution, please can you share it.?!.
thanks.
this is my messege with same problem
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Isometrics-Stub-In-split-Mark-acad-Block/td-p/3749842...
Valued Contributor
batone79
Message 3 of 4 (286 Views)
01-10-2013 08:15 AM in reply to: ybogdanov
Hi Yuri again,
Speaking about this problem, I replay you that my solution was rotate AcadBlock "SplitMark" from properties.
But this solution create a wrong coordinates, so this solution is not good.
Also I change weld node (Only Weld node) to each different pipe some times in manifold and some times in branch pipe, but it is still  not work.
Sorry, any Idea?
Thanks.
Valued Mentor
ybogdanov
Message 4 of 4 (281 Views)
01-10-2013 12:19 PM in reply to: ybogdanov
I don't find any solution in this moment.
Yury Bogdanov
Barcelona (Spain)
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
