AutoCAD Plant 3D General DIscussion
PatrickByrne
Message 1 of 10 (1,316 Views)
Stub-in connection to main branch at known point
1316 Views, 9 Replies
10-17-2012 07:56 PM
We have a main line say DN 400 and a connecting line coming in at 33 degrees from a known point. Therefore I draw the 400 line and draw a construction line where we want the branch to come in. How do we make a connection at that point?
We have tried this, start the branch line, right click and select Stub-in and then select the end of the construction line, but this does not make a connection to the main line. It only works when I select Nearest or Midpoint of the main pipe.
Is there a way to add a marker or node, or any other suggestions.
I did some more testing of this using the standard NEA osnap and that also works well and avoids the need for construction lines etc:
http://screencast.com/t/4vJK3mamoD1
Dan
Product Support
Dan.Scales
Message 2 of 10 (1,249 Views)
Re: Stub-in connection to main branch at known point
10-22-2012 05:27 AM in reply to: PatrickByrne
You could:
  1. Draw construction lines along the header and stub-in axis lines.
  2. Draw a short section of the header pipe so it's midpoint is at the intersection of the construction lines.
  3. Place the stub-in at the midpoint at the required angle.
  4. Join up the pipes.
I hope this helps.
Dan
Dan Scales
Ahmed1081975
Message 3 of 10 (1,236 Views)
10-22-2012 10:20 AM in reply to: PatrickByrne
Can you please Add screen shot Or Vidio
Product Support
Dan.Scales
Message 4 of 10 (1,212 Views)
10-23-2012 04:49 AM in reply to: Ahmed1081975
Here is a short video showing the method:
Stub-in
Dan
Dan Scales
Valued Mentor
Rich.O.3d
Message 5 of 10 (1,206 Views)
10-23-2012 06:27 AM in reply to: PatrickByrne
learning how to use the 'from' snap is the key to mastering stubins...and any kind of branch connection/support manipulation for that matter.
if you have a segment of pipe coming in at 33 degrees, first start the route continuation, then making sure you chose the stub in option from the command line, start you 'from' snap, then start an 'intersection' snap, pick both lines to generate the snap at the stub in location (or use the set out lines that intersect at this point), this will be your 'from' point, now you pick the 'perpendicular' snap to grab the point on the 400 line.
the stub in needs to snap to a location on the actual pipe centreline its stubing into, not the construction geometry.
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Product Support
jason.drew
Message 6 of 10 (1,166 Views)
10-25-2012 05:13 AM in reply to: Rich.O.3d
Hi Rich,
I tested the FROM snap with a stub-in and wasn't able to get it to work. It resulted in a disconnection marker each time I tried.
Let me make sure I'm following the correct steps:
1. Start route from the branch line
2. Make sure stub-end is on
3. Start FROM snap
4. Snap override with intersection
5. Pick both lines
6. Snap override with perpendicular
7. Pick the header line
I think one improvement here would be the availability of object snap and tracking for pipe centerlines without the need for contruction lines, would you agree?
Jason Drew
Premium Support Specialist
Product Support
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
Valued Mentor
Rich.O.3d
Message 7 of 10 (1,116 Views)
10-29-2012 06:14 AM in reply to: jason.drew
ive just been doing some major upgrades...changed both laptop and pc to win7
added ssd drives for the os and apps, created raid for new hdd's, swapped out graphics cards and a couple of other bits and pieces, oc'ed cpu and gpu's etc
still sorting out network, settings & doing reinstalls of software...
I have had the from method working, but it was a bit finiky ...dependant on a certain pick order ill report back in next couple of days, when ive got everthing installed and up and running.
CAD Management 101:
Valued Mentor
Rich.O.3d
Message 8 of 10 (1,101 Views)
10-30-2012 05:35 AM in reply to: jason.drew
thats the procedure i use ...just tested, it connects for me
just make sure when you pick for the perp snap that you are picking on the pipe and not the construction lines
most definately would be much better if you could 'build' a snap using just the pipes
as it is, you can only pick one of the pipes to start the intersection snap but then doesnt let you pick the second pipe. untill its fixed a little bit of construction line work will be required
CAD Management 101:
Product Support
Dan.Scales
Message 9 of 10 (1,091 Views)
10-31-2012 03:18 AM in reply to: PatrickByrne
Dan
Dan Scales
PatrickByrne
Message 10 of 10 (1,038 Views)
11-09-2012 03:40 PM in reply to: Dan.Scales
Thank you for your help, I have been away for the last couple of weeks.
The NEA Osnap works well, I also had a suggestion from Ask the Expert forum to use the line to pipe function on the construction lines. This works well for initial layout and the NEA osnap works well when the main line is already existing.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
