AutoCAD Plant 3D General DIscussion
Valued Contributor
neonade
Message 1 of 4 (784 Views)
Stub Flange for PE pipe cannot connect and extract iso
784 Views, 3 Replies
06-15-2011 11:25 PM
Flange stub cannot connect with flange stub both with backing ring, and also see the attached image, unable to extract error.
Error 2022:IDFGEN has detected disconnected pipeline
Valued Contributor
neonade
Message 2 of 4 (763 Views)
Re: Stub Flange for PE pipe cannot connect and extract iso
06-16-2011 06:19 PM in reply to: neonade
Employee
PeterQuinn
Message 3 of 4 (745 Views)
06-17-2011 02:42 PM in reply to: neonade
You're going to need to supply more information in order for someone to help you. Starting with -  what spec are you usiing?
Peter Quinn
Senior Product Manager
Valued Contributor
bogdanov.y
Message 4 of 4 (739 Views)
06-19-2011 05:45 AM in reply to: neonade
Look in the spec if the diameter DN and OD of the pipe is the same that in the elbow. If the DN or OD is diferent the Plant3D cannot to connect this items.
 In the case of plastic you need to create new fittings and new pipes because DN is don't use in plastics, is used OD. There are for example DN100 and for this diameter there are two diferents diameters outside OD110 and OD125. That's why in the catalog you need to change DN and OD to the same value in all components.
Regards
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
