I need help.
I am making plans in plan view of a storage tank but to generate the view orthographic the structural elements are scaled too and they cover the tanks, as you can fix this problem.
Solved by Matellezm. Go to Solution.
The structural elements of ribbon were created Plant 3D structures unless they are items which doubled to not create new ones.
Arun Kumar K
Thanks for the comment but I solved the problem is not that some structural elements deform to generate an orthographic view but the view obervando trying to identify the elements that are generating corrupted or irregular scaling and replaced with new items.
