AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Structural elements too large in orthographic drawings
3 REPLIES 3
Matellezm
634 Views, 3 Replies
I need help.
I am making plans in plan view of a storage tank but to generate the view orthographic the structural elements are scaled too and they cover the tanks, as you can fix this problem.
3 REPLIES 3
Arun_Kumar_K
in reply to: Matellezm
Seems, you have brought the model from other softwares, which is causing the issue. First convert all into solid objects, then do ortho, u will get.
Matellezm
The structural elements of ribbon were created Plant 3D structures unless they are items which doubled to not create new ones.
Matellezm
Arun Kumar K
Thanks for the comment but I solved the problem is not that some structural elements deform to generate an orthographic view but the view obervando trying to identify the elements that are generating corrupted or irregular scaling and replaced with new items.
”Boost
