AutoCAD Plant 3D General DIscussion
robertstroz8845
Message 1 of 5 (317 Views)
strange hot key behavior since SP1 install
317 Views, 4 Replies
08-23-2012 08:17 AM
     When I use my Osnaps, I use shift+right click, then use a single hot key (as underlined when the menu opens).
Since installing SP1 for 2013, I can only use the hot key once (after a short while I can use a hot key once again), next time I try to use a hot key, it just closes the menu and redirects the key entry into the command prompt.
Any thoughts on what is going on here?  BTW, this does seem to be just in Autocad/ plant as excel still "hot keys" normally.
Thanks, Rob
Looks like the latest SP1.1 for x64 win7 has fixed this issue; although, I did not notice it mentioned within the readme.
Rob.
DarrenP
Message 2 of 5 (310 Views)
Re: strange hot key behavior since SP1 install
08-23-2012 10:46 AM in reply to: robertstroz8845
there is no SP1 for Plant 3d 2013
Employee
LeeKB
Message 3 of 5 (307 Views)
08-23-2012 10:57 AM in reply to: robertstroz8845
Hi Rob,
Could you provide the details of the hot key issue you experieced with AutoCAD 2013 SP1?  You can contact me via my email - kb.lee@autodesk.com directly.
KB Lee
AutoCAD Test Development
robertstroz8845
Message 4 of 5 (272 Views)
Re: strange hot key behavior since AutoCAD 2013 SP1 install
08-25-2012 09:13 AM in reply to: DarrenP
You are correct, this issue also effects using Osnaps in Plant3d (and apparently all other verticals based upon AutoCAD 2013 for which SP1 was installed upon).  I posted it here since my Suite of products are under the Plant design ultimate suite.
I have found others with this problem:
http://forums.autodesk.com/t5/AutoCAD-2013/SP-1-Is-Available/m-p/3593090#M4961
http://forums.autodesk.com/t5/AutoCAD-2013/Mouse-wheel-click-snap-menu/m-p/3593148#M4968
robertstroz8845
Message 5 of 5 (242 Views)
09-12-2012 09:17 AM in reply to: robertstroz8845
Rob.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
