AutoCAD Plant 3D Forum
steel won't show up properly
2 REPLIES 2
eskisa0100
684 Views, 2 Replies
Help! I have to start adding massive amounts of steel to this model today or tomorrow and I cannot figure out how to get it to show up properly.  It had been working fine up until this morning and now it is all messed up.  The I beam and the L beam just show up as a single line and then the I or L in the middle.  Impossible to work with it this way.  I have tried all the visual styles and cannot fix it.  This had happened before and the messing with the visula styles fixed it but it won't work this time.  See attached file.
Please help SOON.  Thank you, Evie
2 REPLIES 2
jabowabo
in reply to: eskisa0100
Change this setting:
eskisa0100
in reply to: jabowabo
Thank you so much.  You saved my life.  I am very new to the steel part of this program. So simple yet not.  Thank you once again for your prompt response.
”Boost
