AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Square clamps in Plant spec
1 REPLY 1
tmccar
325 Views, 1 Reply
How can I set up a square, 2-jaw clamp for use in Plant? The only option I see in Catalog Editor - "Create New Component"  has a round clamp  which wouldn't suit.
  I want to have my spec set up so that when the joint is made, the square-jaw clamps are pulled in from the spec. (Similar to where a bolt set is pulled in when making certain gasket joints)
   Advice would be appreciated.
1 REPLY 1
JarrodMudford
in reply to: tmccar
Create New Component is correct. But you will want to use AutoCAD blocks to define the shape rather than using the parametric blocks available.
Each size will have to be modelled in dwg format and the converted using "plantpartconvert". The following link is a list of videos that will help you.
http://docs.autodesk.com/PLNT3D/2012/ENU/plant/pip/ap3d_movielist.htm
This is the only way that you can get your square clamps into your spec.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Jarrod Mudford
Plant Solutions Consultant
Global Services
”Boost
