AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
SQL versus basic database
3 REPLIES 3
TIMSHANAHAN9157
599 Views, 3 Replies
What are the pros and cons of converting to an SQL database versus the out of the box database system?
Tags (2)
3 REPLIES 3
RSFAdsk
in reply to: TIMSHANAHAN9157
First, if you are considering migrating a project to SQL Express, I highly recommend waiting just a bit longer for AutoCAD Plant 3D or AutoCAD P&ID 2012.
Pros for using SQL Server are primarily improved multi-user performance (and indeed avoiding a Multi-user limitation).
Con are increased admin requirements to deal with the SQL Server, such as backing up the database separately.  Using the default database, you can simply copy the project files.
Richard Frank
Autodesk Knowledge Network
Autodesk, Inc.
JRPalmer
in reply to: RSFAdsk
 How would you intergrate SQL with AutoCAD?
For Plant3D, it can run with a SQLite database, or SQL Server. There is a file in the Plant installation folder to convert the SQLite project to SQL if you want.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
”Boost
