AutoCAD Plant 3D General DIscussion
TIMSHANAHAN9157
Message 1 of 4 (423 Views)
SQL versus basic database
423 Views, 3 Replies
07-29-2011 10:09 PM
What are the pros and cons of converting to an SQL database versus the out of the box database system?
Employee
RSFAdsk
Message 2 of 4 (403 Views)
Re: SQL versus basic database
08-01-2011 08:41 AM in reply to: TIMSHANAHAN9157
First, if you are considering migrating a project to SQL Express, I highly recommend waiting just a bit longer for AutoCAD Plant 3D or AutoCAD P&ID 2012.
Pros for using SQL Server are primarily improved multi-user performance (and indeed avoiding a Multi-user limitation).
Con are increased admin requirements to deal with the SQL Server, such as backing up the database separately.  Using the default database, you can simply copy the project files.
Richard Frank
AEC Plant Solutions
Valued Contributor
JRPalmer
Message 3 of 4 (357 Views)
08-04-2011 02:23 PM in reply to: RSFAdsk
 How would you intergrate SQL with AutoCAD?
Employee
TomislavGolubovic
Message 4 of 4 (339 Views)
08-07-2011 07:14 PM in reply to: JRPalmer
For Plant3D, it can run with a SQLite database, or SQL Server. There is a file in the Plant installation folder to convert the SQLite project to SQL if you want.
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
