How can we generate iso DWGs to be named as follows?
LineNumber-SpoolName
In the meantime, we assign spool ids in 3D piping model and set project properties to read spool name from 3D model, but spool label inside isos do not match assigned spool ids.
Which parameters in isoconfig.xml have to be set?
Farzad
Have you looked through the Plant 3D 2013 Help pages? Here is a item I found that might be what you are looking for.
http://docs.autodesk.com/PLNT3D/2013/ENU/filesPCR/GUID-477FE3BA-ACB1-44DB-82E1-321D9D1C573B.htm
Quentin Contreras
Technical Support Specialist
