AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
SpoolType Iso Naming
1 REPLY 1
312 Views, 1 Reply
How can we generate iso DWGs to be named as follows?
LineNumber-SpoolName
In the meantime, we assign spool ids in 3D piping model and set project properties to read spool name from 3D model, but spool label inside isos do not match assigned spool ids.
Which parameters in isoconfig.xml have to be set?
Farzad
1 REPLY 1
quentin.contreras
Have you looked through the Plant 3D 2013 Help pages? Here is a item I found that might be what you are looking for.
http://docs.autodesk.com/PLNT3D/2013/ENU/filesPCR/GUID-477FE3BA-ACB1-44DB-82E1-321D9D1C573B.htm
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
”Boost
