AutoCAD Plant 3D General DIscussion
Valued Contributor
4 Kudos
Post 1 of 4
Spool Tag on Isometic Box Enclosure
413 Views, 3 Replies
11-22-2011 01:04 AM
Rectangular enclosure for spool tags does not adjust automatically, is there a setting for this that i can deal with.
No resizable enclosure styles are exposed from annotaiton setup in project properties. To use such style, 'IsoConfig.xml' has to be edited manually. Find annotation defintion for 'Spool" and change AnnotationStyle="Rectangle"to AnnotationStyle="SRectangle". SRectangle is a style defined with resizable block.
 <PropertyChangeScheme Name="SpoolNumber" AnnotationStyle="SRectangle" Format="{0}" Enabled="true" Grouping="false" Tag="XX" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Filter="NotBoltWeldFlangeGasket" Field="SpoolNumber" Placement="Along" />
-Weiyu
11 Kudos
Post 2 of 4
Re: Spool Tag on Isometic Box Enclosure
12-19-2011 06:03 AM in reply to: neonade
i have the exact same issue.
where is the support for the new version of isometrics? getting rid of spoolgen was bad enough but there is so little help with the new format.
Employee
1 Kudo
Post 3 of 4
12-19-2011 02:20 PM in reply to: neonade
-Weiyu
11 Kudos
Post 4 of 4
12-21-2011 01:02 PM in reply to: weiyu.xu
why in the world would the default not be set to "SRectangle"? that is just silly.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
