AutoCAD Plant 3D General DIscussion
Valued Mentor
65 Kudos
Post 1 of 4
splitting items in material list
164 Views, 3 Replies
09-13-2012 09:52 PM
i have 2 items placed from a spec.
I want each of the items to have its own line item in the material list.
i thought i could just overwrite the family(size) field with diff descriptions and it would split them, but it doesnt seem to work, it just mashes the two different descriptions together in the list and lists qty of 2.
This is someone elses project, so I cant mess with the settings or methodology.
I just need a workaround to split the items in the material list.
any help appreciated
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Distinguished Contributor
54 Kudos
Post 2 of 4
Re: splitting items in material list
09-13-2012 11:32 PM in reply to: Rich.O.3d
You might have given the item code for both the items as same in spec editor. Please check.
Valued Mentor
65 Kudos
Post 3 of 4
09-14-2012 04:25 PM in reply to: Arun_Kumar_K
thanks for the suggestion, but, sorry, you misunderstood, ill try and elaborate...
It IS the same item from the spec.
I have 2 valves (same type, same size)
the BOM wraps them up and shows 1 item ...vavle with qty=2 (as you would normaly expect)
As I said previously, it not my project, I dont agree with nor like the way they want to show it, but its not my call on this one. So I just need a quick workaround to 'split' the items in the material list.
They want one of the valves to be a line item with description XV-55238
they want the other one to be a seperate line item in the material list with description LCV-55238
Cheers
Rich.O
CAD Management 101:
54 Kudos
Post 4 of 4
09-14-2012 09:31 PM in reply to: Rich.O.3d
I can understand now:
Do like this.
Go to spec editor, say you want to include 250NB valve of same size and rating.
Add twice the valve from the catalog.
Now you have added the valve in your spec. One is original and other is duplicate of that.
Mention the first one with item code -- say x
mention the second one with item code -- say Y
the software ll ask for priority, mention the priority.
Come to the plant3d space, first add the valve with item code x, and add the valve with item code y.
Let me know if you could succeed with this;, i feel this will be the only option.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
