AutoCAD Plant 3D Forum
Spec Update in 3d Modle
3 REPLIES 3
samsonthomas7606
384 Views, 3 Replies
Hello Everybody,
I started a project called Project 6. After this I created one of our steam piping spec (4c-02.03) based on the ASME Pipe and Valve Catalogue. This standard will not show up in the Project 6 or any earlier projects. I did the spec update but the spec  will not show up in Plant 3D spec list.
 Then I started Project 7 and new pipe spec is loaded in Plant 3D spec list. Is there some setting or steps that I am missing? I would like to bring the new spec in the earlier projects that I have started.
Thanks in advance for any suggestions.
Samson T
Piping Design
ALPAC
3 REPLIES 3
philip
in reply to: samsonthomas7606
you will need to copy the new spec files to the existing project 6 spec folder.
in reply to: philip
Hi ,
I also have this such problem. when I load my updated spec in model by running "plantspecupdatecheck" there is comment prompt "there are no spec update available" appears. is there any missing?
Need help anybody who has overcome this problem, thanks
The spec file you want to use in a project should be in the
Project main folder\Spec Sheets
folder.
If you create a new project based on an old one, the new project will have the spec files from the base project.
Attila Vallyon
”Boost
